Activity Forums Adobe After Effects Auto-orient multiple layers as one
  • Auto-orient multiple layers as one
    Posted by Albert Kowalski on August 12, 2019 at 2:30 pm
    Hi!
    I have this problem. I have one big layer that act as a space background. It is very big (25000×20000), because there is lot of zooming in in the animation, so I need it to look full and majestic when it is far away and also not too thin when the camera come close. But when I have a wide angle shot and my camera moves a lot, I need to duplicate this layer, transform it horizontally and put it next to the original one, so my background is even wider.
    Like this (without orienting them towards camera):
    The issue is with a ‘Orient towards camera’ function. With one layer it works fine. But when I put multiple layers next to each other, and they are all Oriented towards camera, they are oriented differently and do not “stick” to each other. Like this:
    So I’m looking for a way to make them act “as one”. I cannot precomp them cause they’re too big. I tried to parent them to the Null, and orient the null, but it doesn’t work. Any other workarounds? Thanks!
    Albert Kowalski replied 6 years, 12 months ago 2 Members · 2 Replies
  • Cassius Marques
    August 13, 2019 at 2:32 pm
    You should use VideoCopilot’s 3d Earth plugin (its free) and set that map as the inner texture of the sphere. (It essentially becomes Red Giant’s Horizon plugin).
    Once you proper tile that texture you won’t have to bother with the orienting. Just scale it accordingly to your camera’s zoom movement.
    Cassius Marques
    http://www.zapfilmes.com
  • Albert Kowalski
    September 25, 2019 at 3:05 pm
    Thanks for the tip. Unfortunately this plugin (VC Orb) loads my texture very slowly and it doesn’t really make my workflow faster. So I’m still looking for a simpler way to solve this 🙂
