Activity › Forums › Adobe After Effects › Auto-orient in only 1 axis
Posted by Graham Quince on April 11, 2005 at 7:54 amHi guys
Does anyone know if there’s a way to auto-orient a layer’s y-axis to permanently point to a camera? I need the X and Z axis to remain static, but have the layer keeps it’s face pointing towards the camera.
Graham
Anthony S mcgrath replied 21 years, 2 months ago 4 Members · 5 Replies -
Yoondo
April 11, 2005 at 8:38 amI don’t think you can auto-orient individual axis. It’s basically locked in all axis.
Mylenium
April 11, 2005 at 9:22 amYou need to re-create the auto orient behavior using a simple expression. Add this to the orientation parameter:
my_orient=lookAt(position,thisComp.layer(“Camera”).position)
X=orientation[0];
Y=my_orient[1];
Z=orientation[2];[X,Y,Z]
You may need to add an angular value to compensate for flipping.
Mylenium
[Pour Myl
Graham Quince
April 11, 2005 at 11:35 am -
Graham Quince
April 11, 2005 at 11:54 amThanks Mylenium,
The only change i had to make is to add a negative setting to the orientation.
my_orient=-lookAt(position,thisComp.layer(“Camera 1”).position)
X=orientation[0];
Y=my_orient[1];
Graham
Anthony S mcgrath
July 14, 2005 at 8:25 amI created a plane and have used this expression to point it at the camera. It only seems to work halfway around then the plane flips.
How would I go about spinning around it fully and avoiding that flip? the nearest example I can think of is the way sprite particles act in Maya.
Do I have to point the plane upward somehow with some kind of upvector? ..I’m really pants at this expression stuff!
