Activity Forums Adobe After Effects Expressions Auto-orient in only 1 axis
  • Auto-orient in only 1 axis
    Posted by Graham Quince on April 11, 2005 at 7:54 am
    Hi guys
    Does anyone know if there’s a way to auto-orient a layer’s y-axis to permanently point to a camera? I need the X and Z axis to remain static, but have the layer keeps it’s face pointing towards the camera.
    Graham
    Tom Gomez replied 15 years, 5 months ago 5 Members · 6 Replies
  • Yoondo
    April 11, 2005 at 8:38 am
    I don’t think you can auto-orient individual axis. It’s basically locked in all axis.
  • Mylenium
    April 11, 2005 at 9:22 am
    You need to re-create the auto orient behavior using a simple expression. Add this to the orientation parameter:
    my_orient=lookAt(position,thisComp.layer(“Camera”).position)
    X=orientation[0];
    Y=my_orient[1];
    Z=orientation[2];
    [X,Y,Z]
    You may need to add an angular value to compensate for flipping.
    Mylenium
    [Pour Myl
  • Graham Quince
    April 11, 2005 at 11:35 am
    Many thanks, that’s worked just as i needed it to
    Graham
    http://www.qcit.com
  • Graham Quince
    April 11, 2005 at 11:54 am
    Thanks Mylenium,
    The only change i had to make is to add a negative setting to the orientation.
    my_orient=-lookAt(position,thisComp.layer(“Camera 1”).position)
    X=orientation[0];
    Y=my_orient[1];
    Z=orientation[2];
    [X,Y,Z]
    Graham
    http://www.qcit.com
  • Anthony S mcgrath
    July 14, 2005 at 8:25 am
    I created a plane and have used this expression to point it at the camera. It only seems to work halfway around then the plane flips.
    How would I go about spinning around it fully and avoiding that flip? the nearest example I can think of is the way sprite particles act in Maya.
    Do I have to point the plane upward somehow with some kind of upvector? ..I’m really pants at this expression stuff!
  • Tom Gomez
    April 5, 2011 at 4:18 am
    Thanks. Very helpful!
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
