Activity Forums Adobe After Effects Expressions Auto Orient Along Path and Rotation Values
  • Auto Orient Along Path and Rotation Values
    Posted by Andy Baumgartner on April 13, 2010 at 2:21 am
    Hi, I have a rolly chair with 5 wheels and a 5 pointed piece. They wheels follow the rotation of a null and the position of the 5 pointed piece which follows the rotation of the null. The problem is, the null is set to auto orient along a motion path, BUT the auto orient command does not actually change the rotation value of the null for some reason, it just visually looks like its rotating. How can I get the individual wheels to auto orient so they are parallel to the motion path and operate how a real rolly chair would? Thanks.
    Andy Baumgartner replied 16 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 13, 2010 at 6:40 am
    I’m not sure this is what you’re after, but it should give the actual world rotation of the null:”
    L = thisComp.layer(“Null 1”);
    v = L.toWorldVec([1,0]);
    radiansToDegrees(Math.atan2(v[1],v[0]))
    Dan
  • Andy Baumgartner
    April 13, 2010 at 3:27 pm
    That worked perfectly thanks Dan!
