Activity Forums Apple Final Cut Pro Legacy Auto mute audio tracks echoing from other mics
  • Auto mute audio tracks echoing from other mics
    Posted by Lawrence Card on May 26, 2013 at 9:39 am
    I shoot a lot of 2 person interviews with lapel mics and find that sometimes (depending on the guest, sound desk settings and room) i get the person talking being picked up on the non talking persons mic. This isn’t a major issue as i want to make sure i’m getting enough level from them and i always record them on opposite channels so i can dip the audio during the edit on the opposite mic to avoid this effect.
    I just wondered if there was a filter of some kind that i can use to automate this laborious process to an extent?
    Alternatively would the fix be that i should be recording audio a much lower levels? (i aim for around -6db to -12db)
    Michael Gissing replied 13 years, 2 months ago 2 Members · 3 Replies
  • Michael Gissing
    May 26, 2013 at 11:08 pm
    Changing level won’t help. The only plugin that might help is a downward expander set to a threshold so that the levels are pulled down unless the threshold is reached. This may have other nasty side effects.
    So nothing beats mixing which is still a manual task.
  • Lawrence Card
    May 27, 2013 at 9:15 am
    ok, thanks for the response i’ll take a look at the downward expander, i guess i need to be recording at lower levels so that i don’t get pickup in the other mic. Unfortunately i don’t have a sensitivity setting on the mic’s that i used which would be the obvious thing to adjust.
  • Michael Gissing
    May 27, 2013 at 11:44 pm
    If you drop the levels on all mics, you still get exactly the same relative spill so that isn’t a solution, just lower levels which might cause other issues.
    Mic placement and mixing are really the only ways to deal with multi mic placement issues.
