Activity › Forums › Adobe After Effects › “Auto levels” effect – out of memory
  • “Auto levels” effect – out of memory
    Posted by Theo Brown on July 1, 2005 at 5:56 pm
    Hello, just curious if any of you have had any problems with ‘auto levels’ under effects>adjust> in AE — it appears as I’m scrubbing the timeline as ‘out of memory’ and then ‘after effects error: auto levels (4). It doesn’t crash the computer; I just lose my preview until it happens again (which is often).
    I’m just trying to “brighten up” several pieces of old footage and would really like for this to work properly because the results look great.
    And, I’m using Win2000 Pro with AE 6.5.1 and have 2GB of RAM – I’ve reinstalled AE and the patch twice now to no avail.
    thanks,
    Craig
    Aharon Rabinowitz replied 21 years, 3 months ago 2 Members · 2 Replies
  • Theo Brown
    July 1, 2005 at 6:34 pm
    Found the answer to my question on the Adobe forums; if any of you are having RAM problems, try this out (i.e., use the ‘secret menu’ and set your layer cache to clear every certain number of frames; I set mine to clear every 90). Why would Adobe have a secret menu? Sheesh…
    Topic
    “throw away” of preview memory
    mischi forster – 11:43pm May 9, 2005 Pacific
    Hi there,
    I have a problem all the time: Well I’ve 2 Gigs of memory, but still the memory gets full so many times after about ten minutes using AE. Is there a way to “throw away” the preview memory so I don’t have to restart AfterEffects to have more ram?
    Well, thanks a lot,
    Michael
    Reply To This Discussion | Back to Topic List | Bookmark | Subscribe
    To start a NEW discussion click on the Back to Topic List link and select Add Topic.
    If you are in an archive forum please go up to the main topic list (archives are read only).
    Messages 4 messages. Displaying 1 through 4.
    First Previous Next Last Show All Messages
    Chris Gannon – 1:01am May 10, 05 PST (#1 of 4)
    Edit>Purge>All
    Post Reply | Bookmark
    tony woode – 4:17am Jun 28, 05 PST (#2 of 4)
    but sometimes (randomly but fairly often) this doesn’t seem to work. You purge the memory but AE seems to hang on to what its doing and refuses to clear the preview
    anyone else had any problems with this?
    David Wigforss – 4:58pm Jun 28, 05 PST (#3 of 4)
    Nope, but if you have problems rendering, try out the “Secret Menu” in preferences.. I think you need to hold shift and then go to prefs.. Hit the back button, and voila, the “Secret Window”. That will allow you to clear it after each frame.
    charles smiley – 8:47am Jun 29, 05 PST (#4 of 4)
    “anyone else had any problems with this?
    Yep. Seems to happen here too. It would be nice if it have a confimation window pop up after it does it ‘thing’. Also it should have a toolbar button so you can click it more often with ease.
  • Aharon Rabinowitz
    July 3, 2005 at 1:58 am
    A little knowledge is a dangerous thing, which is why it’s not out in the open. Using that setting has negative effects. For example, any effect that relies on previosu frames take a lot longer to render – Effects like motion blur and echo time are only 2 examples. Since previous frames are chucked, you have to recalculate for them.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
