Activity › Forums › Apple Final Cut Pro Legacy › Auto-Find Edits
Auto-Find Edits
Posted by Jason Mckee on July 8, 2010 at 12:20 amis there a function in FCP that allows it to auto-find the edits or cut points in a clip and then make a cut at that point. i thought there was a feature that could auto-find reel punches. thanks in advance.
-jmBouke Vahl replied 16 years, 2 months ago 6 Members · 6 Replies -
Shane Ross
July 8, 2010 at 12:59 amI don’t understand you. A clip doesn’t have a cut point until you add one. How can FCP auto-find something that doesn’t exist until you add it? What, in your mind, is a “cut point?”
Shane
Read my blog, Little Frog in High Def -
Jason Mckee
July 8, 2010 at 1:04 amSay you import a movie that is already cut together. I thought read somewhere along time ago that FCP or a similar editor could go through and find the cuts or edits and make a cut at those points automatically. I have never seen such a function but I thought I read something on it. I know I read that either Avid or FCP could look through clips and find the hole punch at the end and beginning of reels after you’ve received the scanned footage.
Jerry Hofmann
July 8, 2010 at 1:20 amThere is a feature that takes advantage of DV’s time of day code in a long capture from DV tape (putting a marker where the camera was paused), but there’s not a way to do this with other than a DV camera master in FCP. There might be some third party software out there that will do this though. Have you googled around for it?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Jon Smitherton
July 8, 2010 at 1:30 amThink HDV does automatically and DV does it if you select clip in browser Mark>DV start/stop detect. For other sources you can use:
https://www.scene-detector.com/
could be quite handy; then again good to go through shots and trim as you have to have a look at what you’ve got at some stage.
Jon
Nick Meyers
July 8, 2010 at 3:16 amyeah, i’ve used scene detector in the past.
i’ve also tried the scene detection in CatDV.scene detector was better for me,
but neither work 100%.
sometimes they miss subtle scene changes, sometimes they erroneously add scene changes in shots with lots of motion.it takes a while to get the settings just so for your particular film.
given the set-up time, and the fact that i didn’t 100% trust the results and would check everything,
i wonder if it’s just as efficient to do it manually.FWIW Scene Detector works by putting markers on the clip in FCP
CatDV gives you an EDL that you an import into FCP and you can then use the offline sequence as a guide.nick
Bouke Vahl
July 8, 2010 at 6:06 amthere is also this:
https://www.videotoolshed.com/product/13/recut
(gives you an XML so you end up with a razored timeline)However, no solution will be perfect.
Flash photography will be a problem, fast cam movements / zooms will be a problem, jump cuts will be a problem….
It’s tweaking the settings and hope for the best.
However, if you have found decent settings for your material, it is about 95 % accurate.Bouke
smart tools for video pros
