Activity Forums Apple Final Cut Pro Legacy Auto distort FCP 7
  • Auto distort FCP 7
    Posted by John Barata on April 24, 2013 at 10:11 pm
    HI,
    I am working on a SD widescreen show right now and everytime I import any 16×9 footage FCP automatically does a -33 distort to it to make it anamorphic. Alot of the clips are coming from after effects so it’s getting aggravating to have to go into every clip and bring the distortion back to 0. Is there any way to stop FCP from distorting the video on import?
    Cheers,
    John
    Rafael Amador replied 13 years, 4 months ago 3 Members · 2 Replies
  • Shane Ross
    April 24, 2013 at 10:21 pm
    FCP is designed to work with broadcast formats. There is no such thing as an NTSC widescreen 16:9 format…not in broadcast. So FCP makes the footage anamorphic, because that’s how you typically deliver widescreen SD.
    No way to change that upon import, but you can copy one clip and paste the attributes (distort) to the other clips.
    Shane
    Little Frog Post
  • Rafael Amador
    April 25, 2013 at 1:56 am
    The footage get that distortion because is interpreted as Anamorphic by FC, so you must to go to the Browser and make sure that the 4×3 stuff is not checked on the “Anamorphic” column.
    rafael
