Activity › Forums › Adobe After Effects › Auto-Comp Names
  • Auto-Comp Names
    Posted by Rich Stahle on July 4, 2005 at 5:28 pm
    Is there a way to edit/stop After Effects (version 6.5) from adding the text “Comp 1” to compositions when you drag media to the comp button and select “multiple compositions”???
    I want the comp names to be the same as the original not adding “Comp 1” to every composition!!
    Underground Music Television
    Mylenium replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mylenium
    July 4, 2005 at 6:15 pm
    Nope, that’s a safety mechanism to avoid having 2 items with the same name. You cannot disable that behavior (unless there’s a secret keyboard shortcut noone told me about???). You could however use a script to create your comps. I think there’s something like that floating around somewhere…
    Mylenium
    [Pour Myl
