Activity Forums Adobe Premiere Pro auto color
  • auto color
    Posted by Miss2z Miss2z on June 20, 2007 at 10:43 pm
    I applied auto color to about an hour’s worth of footage. It took 1 1/2 hours to render. However, after it rendered and I tried to play it back, the color of the video flashes between the non-corrected and the corrected. I tried exporting the piece as a movie and playing it in a different project, but the same thing is happening there. Any suggestions or solutions?
    miss2z
    Miss2z Miss2z replied 19 years, 2 months ago 3 Members · 4 Replies
  • Aanarav Sareen
    June 20, 2007 at 11:06 pm
    I would not recommend using Auto Color, because it doesn’t always work.
    Coming to your problem:
    a) What type of footage are you using? DV? HDV?
    b) Project settings?
    c) Computer specs?
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Miss2z Miss2z
    June 21, 2007 at 12:04 am
    Thanks for responding.
    I’m using DV footage. I’m not sure what more info. you want, but my project settings are at non-drop frame, 48Kh, I have a Dell Latitude D800 single processor.
    Perhaps I’ll just adjust the colors manually?
  • Mike Velte
    June 21, 2007 at 11:19 am
    I prefer the Fast Color Corrector.
  • Miss2z Miss2z
    June 21, 2007 at 1:24 pm
    Thanks. Before your response, I went ahead and tried the Color Balance feature. It took many hours to render, but at least it worked and it plays back without flickering. I’ll try the Color Correction next time.
    Thanks much,
    miss2z
