Activity › Forums › DaVinci Resolve › Auto Color Doesn’t Work Anymore
Posted by Arty Black on September 22, 2011 at 3:41 pmHi All,
The Auto Color command stopped working for me in a running project where it worked before. Not via CMD+A nor via the file menu …
Am I missing something?
Thank You!
Andrew Shtern replied 14 years, 12 months ago 4 Members · 6 Replies -
Dan Moran
September 22, 2011 at 3:50 pmHey Arty,
Have you made sure to add a node, normally when I find auto color is not working it is due to me having deleted all the nodes.
Hope this helps!
thanks,
Dan
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA -
Arty Black
September 22, 2011 at 3:59 pmHi Dan,
Thanks for the quick response. No, I did add a node. I also tried to add a new version but without success.
Might there be something else?
Arty -
Dan Moran
September 22, 2011 at 4:10 pmCan you send me a mail at davincihelp@blackmagic-design.com ?
I should be able to help you out!
Dan
Dan Moran
Ron Nichols
September 22, 2011 at 4:37 pmI found that the auto color will only work when the qualifier tab is selected, it does not work if you leave it on another tab like windows.
Arty Black
September 22, 2011 at 6:07 pmThanks so much Ron! That was the thing I was missing … Thanks a lot!
Andrew Shtern
September 27, 2011 at 9:02 amHi, Dan,
I’ve already sended a mail for you with the same problem, about a month ago.
Still don’t get an answer…Andrew Shtern
Editor/Colorist
The Coffeepost @Kiev, UA
