Activity Forums Adobe After Effects Expressions Auto center text layer anchor point while using an Animator with Flow code
  • Auto center text layer anchor point while using an Animator with Flow code
    Posted by Dagur Maunason on February 15, 2022 at 10:52 pm
    Hello!
    I’m trying to have a text field automatically center both horizontally and vertically while using an Animator with some code from Flow driving the animation. It’s mostly working as needed, until I change the Y offset in the animator above 52, then the whole text field make a large jump vertically at two different times during playback.
    I cannot for the life of me figure out what makes this happen, though I have noted that if I increase the font size that fixes it. I fear that it’s some kinda clash between the expressions, but perhaps I have just written it poorly and there is a simple solution. Does anyone have any ideas on how to fix this?
    Many many thanks in advance!!
    Dagur Maunason replied 4 years, 7 months ago 2 Members · 2 Replies
  • Andrei Popa
    February 16, 2022 at 6:41 am
    Hi Dagur.
    Try changing the 4th row to this
    var rowCount = Math.round(targetObj.sourceRectAtTime(0,false).height/txtSize);
    Andrei
  • Dagur Maunason
    February 16, 2022 at 10:41 pm
    I thought I tried that but apparently not properly if so.. All good now, and I could even remove row counting etc since sourcerect is now read before animation as intended. Thanks a ton Andrei!!
