Activity Forums DVD Authoring Authoring SD video on BluRay DVD
  • Authoring SD video on BluRay DVD
    Posted by Stewart Hill on February 17, 2011 at 4:09 am
    Hello,
    Is there a way to take a 25 min. analog video and record it onto BluRay uncompressed? If you had a longer analog video, what codec and software could I use to minimize the compression and fill the BluRay disc?
    Daniel Ludwig replied 15 years, 6 months ago 2 Members · 3 Replies
  • Daniel Ludwig
    February 17, 2011 at 8:56 am
    hi stewart,
    should it be a blu-ray t obe played on blu-ray-players? so you need to go bd-specs.
    in that reason you need to transcode your video-files to MPEG2, H264 or VC-1 and author the disk with a bd-authoring-software.
    if you just wont to have your HD-movie on disk (as file), you could use any burning-sofware that could handle UDF2.5/2.6.
    cheers
    danny
  • Stewart Hill
    February 17, 2011 at 6:04 pm
    Hey Danny,
    Thanks for the info. What do you mean by bd-specs? I want to end up with a file format on a Bluray disc that will play back in a BluRay player.
    Best,
    Stewart
  • Daniel Ludwig
    February 17, 2011 at 6:45 pm
    hey stewart,
    aaah – that was the missing information! 😉
    if you would like to create a BD that will be playable on BD-players you need to go VC-1, MPEG2HD or H264 by spec.
    you can transcode the film using adobe media encoder CS4/5, or if you are working with FCP7, you can select compressor to transcode your video.
    I would choose h264 – it´s a high-quality-codec that will save a lot disk-space compared to MPEG2HD at the same bitrate. you can choose much lower data-rates to get the same result than MPEG2HD.
    for your audio choose AC-3 dolby digital.
    if you are using adobe media encoder be sure to use H264 blu-ray settings.
    if you´re authoring with adobe encore, be sure to create the project-file with the correct transcoding-settings, otherwise all your assets will be transcoded again.
    cheers
    danny
