Activity Forums Adobe Premiere Pro authoring problem
  • authoring problem
    Posted by Lillian Fidler on July 9, 2009 at 1:23 am
    Hi:
    Everytime I try to build to a folder or disc in Encore I have problems. If it’s to a folder I get a ‘memory allocation error’ I heard somewhere that if the audio is longer than the video it could produce an error. The audio did come in longer (by alot) and I trimmed it down to the same size (just by rolling it back). still no luck. I’m not sure why it comes in longer anyway as the mpg file that I’m importing is only 3.5 minutes long but the audio is coming in at 21 minutes long. I’m thinking that this is related somehow because when I delete the audio track and build it works fine… any suggestions?
    This could possibily be something quirky?
    Thanks in advance.
    Lillian
    Lillian Fidler
    Jillian Productions
    St. John’s, Newfoundland
    Canada
    Jon Barrie replied 17 years, 2 months ago 2 Members · 1 Reply
  • Jon Barrie
    July 10, 2009 at 2:25 am
    Sounds like you have a theory to you issue. Why don’t you re-export the audio to the correct length from the premiere project and see if it all works.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
