Activity › Forums › Compression Techniques › Authoring DVD… should I use Bottom Field First or Progressive?
  • Authoring DVD… should I use Bottom Field First or Progressive?
    Posted by Rajnesh Domalpalli on January 29, 2007 at 12:12 pm
    Hi All,
    I’m using Compressor to write Mpeg-2’s for a DVD that will be watched on TV.
    I was wondering whether I should use Progressive / Bottom Field First / Automatic for the Format Specification?
    My input is Uncompressed 10Bit 4:2:2 1920x1080p Quicktime material.
    I was told that I should use whatever the kind of TV is (progressive/ interlace). But I don’t know what the end users will have…
    Thanks in advance for your help.
    Regards,
    Rajnesh
    Ben Waggoner replied 19 years, 7 months ago 2 Members · 1 Reply
  • Ben Waggoner
    February 18, 2007 at 8:04 am
    What’s the frame rate of your source?
    If it’s 30p, encode as interlaced.
    If it’s 24p, encode using Compressor’s “24p” mode, which will make it have the proper 3:2 pulldown (top field first, I believe, but it doesn’t really matter).
