Activity › Forums › DVD Authoring › Authoring DVD… should I use Bottom Field First or Progressive?
  • Authoring DVD… should I use Bottom Field First or Progressive?
    Posted by Rajnesh Domalpalli on January 29, 2007 at 11:13 am
    Hi All,
    I’m writing MPeg-2 files to Author a DVD, and I’m using Compressor.
    My input is a Quicktime movie Uncompressed 4:2:2, 1920x1080p.
    In compressor, for the Format, should I choose Automatic / Bottom Field First / Progressive?
    The DVD will be viewed on TV’s at home. So I guess, my question is, are most TV’s now-a-days Progressive or Interlaced?
    Thanks in advance for your reply.
    Regards,
    Rajnesh
    Daniel Low replied 19 years, 8 months ago 3 Members · 2 Replies
  • Roman Melekh
    January 29, 2007 at 1:55 pm
    If source video is Progressive you can set bottom or top.
    “Progressive” flag is not DVD-VIDEO standart
  • Daniel Low
    January 31, 2007 at 12:53 pm
    CRT based TVs are interlaced (some have a progressive/deinterlacing option)
    Plasma & LCDs are progressive.
    As such if you encode to progressive it will look great on the Plasma/LCDs but possibly jerky on the CRTs, if you encode to interlaced there’ll be a slight drop in quality on both types of TV.
    If it were down to me, I’d encode to progressive as most people I know use a Plasma and pretty well all modern DVD players have progressive support (I’m in the UK so you mileage may vary)
    https://www.dvddemystified.com/dvdfaq.html
