Activity Forums VEGAS Pro Authoring a DVD to replace a powerpoint presentation
  • Authoring a DVD to replace a powerpoint presentation
    Posted by Joseph Dezordi on May 17, 2005 at 10:35 am
    I use DVD to give lectures, with videos of a subjects followed by some text slides…I have used Vegas to construct an MPG 2 file, & I use the pause button to give the illusion of a static slide…of such things such as
    graphs or tables ….as I find powerpoint unstable when it come to showing videos …using a DVD bypasses the problem of windows crashing during a presentation ….
    I some times use photo shop to construct the text for the slides, but I find this awkward..
    can any one advise me how to do ths more efficiently..
    also..
    1. What is a good & simple way to construct graphs & put them into a DVD presentation?
    thanks for your help
    Joseph Dezordi replied 21 years, 3 months ago 3 Members · 5 Replies
  • Edward Troxel
    May 17, 2005 at 1:14 pm
    What if you use Excel to create the graph and then save it as an image to be imported into Vegas?
    Edward Troxel
    JETDV Scripts
  • Joseph Dezordi
    May 17, 2005 at 1:24 pm
    I will try, is it better than the graphing in WORD ?
    After this post
    I did a test with creating a graph in Word & sent it to Photoshop… then into Vegas as a JPEG… It worked ….
    When Architect makes a slide show, isnt it really turning jpegs into MPG2 Video??
  • Edward Troxel
    May 17, 2005 at 3:35 pm
    Word should be sufficient. When creating Graphs, I just think of “numbers” which makes me lean toward Excel. Either should work fine.
    Edward Troxel
    JETDV Scripts
  • Seth Bloombaum
    May 17, 2005 at 5:02 pm
    Powerpoint is usually very stable with video. It likes WMV and MPEG-1. Perhaps there is some other issue with your PC.
    The quickest way to create slides is in… Powerpoint! You could then “save as” png for use in Vegas or DVDA.
  • Joseph Dezordi
    May 17, 2005 at 9:37 pm
    ok thanks, I will try the PNG idea, I never knew that, thanks,
    lastly, is it possible to create a ‘ a true slide show using DVDArhcitect….? it seems to me that ‘ the slide show which has up to 100 ‘slides’, is actually a movie
