Activity Forums Adobe Encore DVD Author a 480p (24 fps vs 23.973 fps) DVD
  • Author a 480p (24 fps vs 23.973 fps) DVD
    Posted by Ikarus79m on April 3, 2006 at 9:15 am
    Hello guys,
    we just finished our 35mm student film which we put through the Digital Intermediate at a 2K reolution. I just received my 2k files and exported them as a 24 fps 720×480 anamorphic uncompressed video.
    When I take this 24fps file and import it into Adobe Encore, it prompts me to convert it to mpg, but instead of 24fps uses 23.973 fps. If I try to feed Encore a 24 fps mpeg created with CCE it still wants to convert it. Why is that?
    I thought since my source material is progressive at 24 fps i should be able to make a 24 fps DVD. Was I mistaken? Is there no such thing as a true 24 fps DVD? I thought I was able to make a 24 fps DVD which if played through a Progressive Scan DVD player to a Prgoressive able TV will just show at 24 fps, and if played to a regular TV will play at 29.97 through 3:2 pulldown done by the DVD player.
    I’d truly appreciate if someone could shed some light on my confusion.
    Thank you!
    Philipp
    Tim Kurkoski replied 20 years, 5 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    April 3, 2006 at 9:06 pm
    That is correct. 24P footage needs to be 23.97. The DVD spec does not allow for 24fps, so to work around it all 24fps footage is converted to 29.97 with 3:2 pulldown flags.
    I’ve never heard of a TV that plays 24fps natively. All TV’s (including LCD’s, Plasma, etc.) run at 60Hz (essentially 60fps). For HD progressive material they just don’t change the image every frame. For non-HD displays 3:2 pulldown is used to match the interlaced display. 24fps produces a noticeable flicker to the eyes, and it would be terrible with a bright video display. (Even film projectors run the shutter in front of each frame at least twice to avoid flicker.)
