Activity Forums Broadcasting Australia broadcast luma and chroma limits
  • Australia broadcast luma and chroma limits
    Posted by Craig Ricker on February 15, 2013 at 5:53 am
    Hi there,
    Trying to find out what the broadcast safe limits are for luma and chroma in Australia.
    Is it different per broadcaster?
    Just want the gist:
    is it 0-100 on luma
    -20 to 130 on chroma?
    Mac Pro 2 x 2.4Ghz, 16GB RAM, GTX 660
    Andrew Rendell replied 13 years, 6 months ago 2 Members · 3 Replies
  • Andrew Rendell
    February 17, 2013 at 5:46 pm
    AFAIK, the main broadcasters in Australia are members of the ITU, so regular Rec.709 levels are what they require.
    https://en.wikipedia.org/wiki/Rec._709
    https://www.itu.int/dms_pubrec/itu-r/rec/bt/R-REC-BT.709-5-200204-I!!PDF-E.pdf
  • Craig Ricker
    February 18, 2013 at 2:14 am
    So I had a read through that document. Didnt discuss DV Pal, rather it was in regards to HD broadcast, but assuming they wish to have the same levels I found this to be what they said.
    So assuming I am reading this correctly, the levels for broadcast are not 0-255, but rather 16-235 for luminance.
    Could not see what chrominance values are supposed to be?
    I have heard to not go over 75% on the vector scope, though would like to know what values that means so I can simply apply the video limiter effect and set it up right.
  • Andrew Rendell
    February 19, 2013 at 7:00 pm
    Ah, didn’t think of SD, but yes 16 – 235 is right.
    75% on the chrominance is a decent rule of thumb.
    TBH, I would advise against using clippers to set maximum levels without at least setting them roughly right first.
    I don’t know which video limit effect you’re using, there are a few and they don’t all set up the same.
