Activity Forums Adobe Audition Audtion 1.5 Eidt Original
  • Audtion 1.5 Eidt Original
    Posted by Trey Selman on August 21, 2007 at 6:00 pm
    In Premiere Pro CS3, is there a way to set the Edit Original for audio to go open the source file in Audtion 1.5?
    Trey Selman
    Blast1 replied 19 years ago 3 Members · 2 Replies
  • Willie Toth
    August 21, 2007 at 9:53 pm
    I haven’t tried but because Adobe has created Soundbooth, (what a laugh) as the default audio editor for the CS3 package it may not … See if you can access through adobe bridge, personally after I edit the seqence I export the audio fix what I need to in audition then replace the original audio with edited version
  • Blast1
    August 22, 2007 at 6:13 pm
    I think all you have to do is set the win file preferences “open with” to 1.5 for the type of file you want to open like a .wav or mpe, etc.
