Activity Forums Apple Final Cut Pro Auditioning grades and lower thirds
  • Auditioning grades and lower thirds
    Posted by Brendan Gibbons on June 28, 2011 at 12:15 pm
    I am really liking the auditioning function when applying colour grades to shots. Apply your first correction / filter, tweak settings and then select duplicate in audition window.
    Then like in apple color you can stack up your grades and easily switch between them on the fly.
    What is also quite handy, but barely gets a mention in the manual, is that you can audition text effects in the same manner, letting you get a feel for a number of different graphical styles on the fly.
    On the same topic it would be good if you had the option of the audition clips adhering to the duration of the first clip.
    Just thinking aloud…
    cheers,
    brendan
    Brendan Gibbons replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
