Activity › Forums › Adobe Premiere Pro › Audition set audio
  • Audition set audio
    Posted by Tomi Foldes on November 19, 2012 at 12:51 pm
    Dear Friends, i might have a silly question but it’s important for me. I need to set the audio for a local tv channel for this specific settings: reference level -18db,peak amp: -12db, true peak: -6db, and -23 LUFS. With Adobe Audution i can set with match volume to -23 LUFS, but i changes every other setting to. Could you help me how to set each level individually? Thanks a lot.
    Tomi Foldes replied 13 years, 10 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    November 26, 2012 at 4:56 am
    Reference level is ambiguous, probably the amplitude of the reference tone. Ask the station for clarification. Audition has a simple tone generator if I recall.
    Peak at -12 is for most audio, usually dialog. I would set a soft compression at -15 and let it roll off at a 3:1 compression. Anything that isn’t compressed by that probably needs a little volume mixing.
    True peak at -6 allows some peaks to go through the -12 threshold… maybe sfx like bullets and so on. I would set a hard limiter for -6.1db. You really don’t want any peaks above the true peak, as it’s an engineering requirement, not an artistic decision.
    Also, don’t rely too heavily on “match volume”. I find it doesn’t work too well on clips that are too quiet, they usually need a boost to read at the proper LEQ(A) level. LEQ(A) and LUFS are very similar measurements, if I recall, if not different names for the same thing.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Tomi Foldes
    November 26, 2012 at 8:18 am
    Dear Angelo, thank you for your answer and have a nice day 🙂
