Activity › Forums › Adobe Audition › Audition CS6 Quicktime levels workflow?
  • Audition CS6 Quicktime levels workflow?
    Posted by Craig Cole on January 2, 2013 at 5:16 pm
    Using Audition CS6 to adjust audio levels for HD spots.
    Workflow is:
    1) Render out spot as 1080 Quicktime from After Effects.
    2) Adjust/master the audio in Audition CS6
    3) then SAVE that treated audio back into the self contained Quicktime file.
    4) Compress for Broadcast with Media Encoder CS6.
    Is the 3rd step possible inside Audition?
    I just see the option to save as a seperate Audio file.
    I’ve read some iffy work arounds using QT Pro but would much rather use Audition for all audio work.
    Anyone have a dependable workflow for this situation?
    Most stations we work with are switching to the -20db standard.
    Thanks for any help!
    Craig Cole replied 13 years, 9 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    January 3, 2013 at 2:54 am
    Adobe products are great at creating media, not a lot of strength with manipulating the file itself. I doubt Audition can do it, unless I’m missing some obvious feature.
    I would look into using a command line tool like FFMPEG or it’s more broadcast format friendly cousin FFMBC.
    With them you can do stream copying. In layman’s terms lets say you have an AE comp rendered out and an audio mix. FFMPEG can combine them in a way that doesn’t re-compress them. It just puts them in a container together; MOV, MXF, etc.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Craig Cole
    January 3, 2013 at 3:02 pm
    thx Angelo, i’ll look into that.
