Activity Forums Adobe Audition Audition CS6 – Mixdown keyframes are slightly off
  • Audition CS6 – Mixdown keyframes are slightly off
    Posted by Bob Seifert on June 28, 2012 at 3:27 pm
    Hi, I’m trying to export a song from Audition. When playing the session it sounds fine, I have a number of volume envelopes to edit out breath sounds on the vocals and the playback sounds great. However, when I either Mixdown Master to a file or bounce it to a track all of my vocal volume envelope keyframes are slightly off and the entire file is about 5 db more quiet.
    With the keyframes slightly off, rather than precisely editing out a breath sound, I now hear some of the breath and part of the lyric is cut off, it’s like everything is shifted ahead by a few milliseconds.
    I don’t understand why the mix down doesn’t sound exactly like playback on the session. Must be something I’m doing wrong. My workflow looks like this:
    Individual instrument and vocal tracks -> Vocal and Instrument Busses 1 (some effects) -> Vocal and instrumental Busses 2 (compression and volume envelopes) -> Master. And like I said before just playing Master within the multirack session sounds perfect, it’s just after mixing down or exporting or bouncing that things get off sync.
    Thanks in advance!
    Mitch Rosefelt replied 13 years, 6 months ago 3 Members · 2 Replies
  • Durin Gleaves
    July 10, 2012 at 5:03 pm
    Hi Bob,
    I’m not sure why your keyframes would be offset. I haven’t seen any other reports of that behavior, but I’ll spend a bit of time looking into it today.
    As for the overall volume drop on mixdown, this is a result of honoring the Panning Law:
    https://en.wikipedia.org/wiki/Pan_law
    https://www.samplecraze.com/tutorial.php/35/panning-law/
    By default, Audition reduces the gain for stereo material panned to the center by -3dB. You can override or customize this by going into Preferences > Multitrack and changing the Panning Mode to Left/Right Cut (Logarithmic) or adjusting the dB Center hot-text value.
  • Mitch Rosefelt
    February 18, 2013 at 3:29 am
    Did you find a fix for this? I’m having the same problem with a .sesx where all the pan keyframes are offset in the mixdown. Bummer!!!
