Activity Forums Adobe Audition Audition CC: Noise reduction reduces everything BUT noise
  • Audition CC: Noise reduction reduces everything BUT noise
    Posted by Deborah Sovierzoski on June 6, 2014 at 6:01 am
    Hey guys,
    I am having a problem with audition i’ve never had before. I’m assuming it’s an easy fix but I just can’t figure it out.
    I am trying to reduce air con noise in an interview. I capture a clean noise print, select all. But when I go into the reduce noise effect, it reduces everything BUT the noise print. It’s removing the voice and leaving the noise, the opposite of what i want it to do!!
    Here is a video showing my step by step process. The video has no audio, but you can see by the waveform what’s going terribly wrong.
    https://vimeo.com/97499230
    Has anyone had this happen before?
    It used to work fine in the past, and just decided to not work. I have restarted, reset the effect, nothing.
    Thank you!
    Deb
    Jeff Kay replied 12 years, 1 month ago 3 Members · 3 Replies
  • Mo Salhan
    June 8, 2014 at 6:32 am
    check out this short youtube tutorial that could maybe help you!
    https://www.youtube.com/watch?v=Gq1an6E-tmI
  • Deborah Sovierzoski
    June 11, 2014 at 11:44 pm
    Hey Mo,
    Thanks for the response (great tutorial by the way, thanks for helping to teach others!), but I have been following those exact same steps. I find the area with only noise, capture print, select all, remove noise. But it removes only the voice and leaves the noise. If you see the video i posted it shows my dilemma.
    It looks like no one else has had this problem! Maybe it’s the audio file? I may try a file recorded off something else, maybe that is the problem.
  • Jeff Kay
    August 10, 2014 at 9:50 pm
    In the video you have “output noise only” checked.
