Activity Forums Adobe Audition Audition CC 2014 Sync Issues
  • Audition CC 2014 Sync Issues
    Posted by Sean Franklin on September 17, 2014 at 5:44 pm
    Hi all,
    I’m having a strange issue where Audition actually plays audio from a clip in the multitrack window earlier than it should. For example, while I’m scrubbing the audio of a clip sometimes begins to play before the playhead is even over the clip. I’m trying to sync up a few things manually and this is making it much more difficult.. Any ideas?
    Tim
    Tim Franklin
    Freelance Visual Effects Artist/ Video Editor
    Media Asset Manager, CBS Sports Network
    http://www.TimSFranklin.com
    Sean Franklin replied 11 years, 11 months ago 2 Members · 2 Replies
  • Durin Gleaves
    October 1, 2014 at 5:27 pm
    Hi Tim,
    I know this reply is a bit late, but is this still a problem? There are two reasons I can think of this behavior might occur. The first would be a very high audio buffer size and the other would be a high latency effect such as Full Reverb being used on the track. Do you experience this only while scrubbing, or do you notice it during real-time playback as well?
    Durin Gleaves
    Adobe Audition
  • Sean Franklin
    October 1, 2014 at 5:34 pm
    After doing a few more tests it does seem that this only happens during scrubbing. I’m assuming now that this is a feature Adobe added which maybe in some cases is helpful? The only effects I’m using are Multiband Compressor and Parametric Equalizer. Would these be the culprit? It would be great if there was a way to turn this feature off if it is one.
    Thanks for the reply!
    Tim Franklin
