Activity › Forums › Adobe Audition › Audition 3 With Creative Soundblaster Live
Posted by David Anderson on May 28, 2008 at 4:16 amI can’t get adobe audtion 3 to recognize my external soundcard, which is a creative soundblaster live 24-bit.
Please help.
Thanks in advance,
David
Emmett Andrews replied 18 years, 4 months ago 3 Members · 8 Replies -
David Anderson
May 28, 2008 at 1:24 pmI’m going to edit>audio hardware setup and the only options I see are the default laptop speakers and mic.
How do I find the rewire option and what exactly is it supposed to do>
Dave
Willie Toth
May 28, 2008 at 2:15 pmIn the options tab go to device order and there should be a tab that gives you the rewire option … Rewire allows Audition to see outboard hardware ………. WILLIE
incidental poet
David Anderson
May 28, 2008 at 5:03 pmHey, Willie. There’s no “Device Order” under options. This is what I see:
loop play mode
timed record mode
metering
midi trigger enable
synchronize cursur across windows
windows recording mixer
stard default windows cd player
preroll and postroll optionsDave
Willie Toth
May 28, 2008 at 6:19 pmGo to your help file and look up REWIRE … I refuse to use anthing above Audition 1.5 …………. WILLIE
incidental poet
David Anderson
May 28, 2008 at 6:56 pmThanks, Willie. I found rewire setup under Edit, but it won’t let me do anything. It says, “No rewire slave applications found on this system.”
I have a Creative Soundblaster live 24-bit external soundcard plugged in.
Any thoughts?
Dave
Willie Toth
May 28, 2008 at 7:06 pmGo into your control panel, then sounds and audio device and make your external soundcard the default soundcard for your system and that should take care of your issues …You may have to reset Audition to make it the default for the program ……… WILLIE
incidental poet
Emmett Andrews
May 31, 2008 at 12:09 amReWire has nothing to do with hardware…It’s for patching and controlling programs like Reason or Live via Audition. Yours should be as simple as selecting the proper hardware in your options. Is the card working with things like media player? If so, you may need ASIO4ALL, a free ASIO driver that works with WDM interfaces.
Emmett
