Activity Forums Adobe Premiere Pro Audio/video synchronizing problem
  • Audio/video synchronizing problem
    Posted by Andreas Andrea on May 29, 2013 at 8:02 am
    I recorded an event recently, and made a stupid mistake. I had my main camera record 1080 29.970fps footage, while my second camera (a GH2) was set on 25fps. My main audio was from a recorder.
    The thing is, when I try and synchronize the clips from the two cameras to the audio, using PluralEyes, the clips shot in 29.970 synchronize perfectly, while the clips shot in 25fps come out of sync every few minutes.
    What’s the best way to resolve this? I tried converting the 25fps clips to 29.970 and synchronizing again, the problem is still there. Should I also change the speed of the clips in addition to the frame rate? Perhaps someone more knowledgeable than me can offer some inside.
    Kris Merkel replied 13 years, 3 months ago 2 Members · 1 Reply
  • Kris Merkel
    May 29, 2013 at 1:36 pm
    Plural eyes uses audio sample rate to line up the footage, so when you are conforming your 25p footage make sure that your audio bit depth and sample rate match the other footage exactly.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
