Activity Forums Avid Media Composer Audiosuite Limiter Plug-in Suggestions or Quick-tut
  • Audiosuite Limiter Plug-in Suggestions or Quick-tut
    Posted by Matt Bacon on June 16, 2010 at 1:29 pm
    Hello,
    I am doing a final audio mix in Media Composer 3.0. There is no option for additional post-audio, and I don’t have Protools.
    My standard work flow is as follows:
    -manually balance my clips using clip gain,
    -using Audiosuite, apply a compressor/limiter effect to individual clips when needed
    -mixdown audio for final prints
    Using the compressor/limiter:
    After manual balancing, none of my clips hit 0, and only my vocal tracks are (occasionally) peaking above -8.
    I like the Dyn 3 3rd party plug-in that came free with something somewhere once, and I use it with a self-taught, rudimentary understanding.
    I set my threshold around -30 (depending on the clip), give it a nice knee, keep the ratio between 3:1 and 5:1. I like to keep my attack at 10 ms, sometimes I put it at 5 ms if the vocals are fast and poppy, and I leave my release at 80 ms (or 100 ms if I shorten my attack). I apply a gain if necessary to boost my newly compressed audio up to between -14 and -8.
    At this point i’m mostly happy, but i’ve still got the occasional audio pop rising above -8.
    I don’t want to go through and keyframe out every pop, and when I try shortening the attack on some of the poppy clips, it sounds horrible.
    My Questions:
    1) Can anyone recommend a mastering limiter effect with really basic controls, which I can apply to my final mix-down? I’m looking for something that lets me set a wall, and lets me set it by entering a value, not adjusting knobs. In other words, I want to tell the effect “My wall is -8 db” and then render. I’ve heard limiters with interfaces like this exist, but search engineing yields poor results.
    2) Alternatively, can someone break-down the relationship between typical compressor and limiter controls for me? I understand my threshold is setting the level at which audio is affected, and I understand that the higher the ratio the harder the compressor works, but there must be a way to calculate (at least approximately) what level i’m limiting a given clip too… or is this wishful thinking?
    I need more knowledge.
    Thanks for your time and energy,
    Bacon
    Job Ter burg replied 16 years, 2 months ago 3 Members · 3 Replies
  • Job Ter burg
    June 16, 2010 at 3:05 pm
    Massey’s L2007 works for me. Very easy to use. Absolute brickwall limiting.
    Only 89 USD. I use it on my Avid.
    https://www.masseyplugins.com/?page=l2007
  • Matt Pascale
    June 25, 2010 at 12:25 am
    hey Job, mind if i ask what you workflow for using this plug in is? do you apply it to clips individually or do you mixdown and then apply it ?
    thanks
    -Matt
  • Job Ter burg
    June 25, 2010 at 5:32 am
    I apply it to mixdowns. Or, in MC5, as an RTAS effects to a track.
