Activity › Forums › Apple Final Cut Pro Legacy › Audiofilter “Away sound”
Posted by Tobias Schrenk on January 17, 2009 at 11:44 amHello,
I am really new to Final Cut and I am searching a secial audiofilter but can´t find it. I want to parts of the noises sound like they were in a other room.
Don´t know how to describe it any better, I hope someone can help me.
Thanks a lot
Dustin Dowling replied 15 years, 1 month ago 6 Members · 5 Replies -
Jerry Hofmann
January 17, 2009 at 2:36 pmMight try just changing the EQ of the audio (making it sound thinner with less dynamic range), and then adding a touch of echo or reverb to it might give you what you’re after.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Andy Mees
January 17, 2009 at 2:44 pmTobias,
Just as Jerry’s suggestion here’s a nice recipe
1) add the Audio Filters > Apple > AUFilter
set low filter type to low shelf
set low frequency to 800
set low gain to -18
set center gain 3 to -18
set high filter type to low pass
set high frequency to 3500
set high gain to -18
2) add the Audio Filters > Final Cut Pro > Reverberationsee how it sounds and tweak the settings to taste
… or how about just re-recording the audio through a wall?
cheers
Andy -
Arnie Schlissel
January 17, 2009 at 8:09 pmFurther to Jerry & Andy’s suggestions: which side is the other room on? Pan it waaaay over to that side.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Michael Gissing
January 19, 2009 at 12:08 amBy far the best way to do this is with a convolution reverb using a sample that is recorded at a distance and through a wall. FCP doesn’t have the ability to use this type of software but it can be run stand alone on a VST software host. SIR2 is a brilliant and cheap convolution reverb and there are heaps of sampled environments to use freely available on the web.
The main thing that is attenuated by distance and walls is high frequency so rolling off low frequencies is optional. Reverb should be set for a short decay but an initial delay of at least 40 msecs.
If all of this sounds like double dutch, then you begin to appreciate the value of going to sound post pros who not only understand but have these tools. FCP is not an audio editor or mixer. For audio it is only an offline tool compared with dedicated audio systems like Fairlight etc.
Dustin Dowling
August 25, 2011 at 1:25 ami know this is an old post, but those settings worked perfectly.
thanks.
