Activity Forums Adobe Audition Audio Workflow
  • Audio Workflow
    Posted by Dustin Barrons on December 19, 2006 at 1:51 am
    Hello,
    I was curious if anyone had any ideas on various type double system audio workflows for digital video. I currently have an old ADAT blackface I use when shooting shorts, then sync using a clapboard. Nothing too fancy. However, I would like to think about purchasing a porta-DAT eventually, and was curious on any suggestions you may have about a workflow.
    Examples:
    1. Initial syncing to digital video. Also, what about monitoring for various people on set. One of the reasons I like the rackmountable ADAT is that I can send signals out to a headphone monitor and also back to playback (which, I would like to use DVRACK eventually for audio and video on-set playback). The only current disadvantage is ADAT’s quality loss and the fact that I must haul 4000 pounds of audio equipment on every shoot (which isn’t necessarily a problem… I never really liked my back anyways :).
    2. Bringing of audio into a home editing system (hardware, I hear MOTU and Digidesign make pretty good firewire hardware… also, what hardware could accept multi-track ADAT and DAT if necessary)
    3. Various softwares I could use to work with video and how the workflow would work in post (I currently am using Adobe Premiere Pro 1.0 for video (yes, I know, I need to upgrade to 2 🙂 and was wondering how Adobe Audition was. I’ve used Cakewalk and Cubase way back in the day, but nothing for video) … (as far as post workflow, should I sync audio in Premiere, then export out to an audio program for sweetening and mixdown, or what?)
    4. What about working with 5.1, how does the software flow work in that respect?
    5. Lastly, any other suggestions… like, should I purchase a good set of monitors? What hardware would support that.
    I am on a somewhat tight budget and am not looking to completely revamp my house into a studio. Nor do I think going to a audio post-house for mixdown on every short I do to be a good idea (unless I hit the lottery, of course). Just some suggestions on what I could possibly do to make my audio mixes better. Perhaps I could buy a little piece at a time…. hmmmmm….
    Dustin
    Willie Toth replied 19 years, 9 months ago 2 Members · 1 Reply
  • Willie Toth
    December 19, 2006 at 2:30 pm
    Dustin
    There are a lot of better portable units out there than ADAT,
    but the mere mention of ADAT did bring a smile to my face of
    fond memories, thanks … Do you have a laptop if so you can go
    with a firewire unit and record directly to the laptop using
    Audition … I have a friend who uses this unit and swears by
    it …
    https://www.americanmusical.com/item–i-PRS-FIREPOD-PAK.html
    Personally because I do a fishing program and space is very
    limited I just use wireless and plug them directly into the
    camcorders … I have an Panasonic AG-DVC 30 with the external
    mic pre and it’s a great setup for my application … If I need
    more than 2 mic’s I plug them into my B cam and all of a sudden
    my 4000 pounds went down to a fraction of that and I get great
    audio as well, just need to tweak a bit in Audition …
    The firepod can work for this application also but if you use a
    laptop on location you don’t have the transfer loss that you
    talked of earlier …
    Pre Pro and Audition are very compatible … My workflow is as
    follows
    1. Capture and edit sequence
    2. Export audio, (you are one of the first that has posted
    that does does this step, Kudos to you)
    3. This really is an important step and sounds involved but
    really isn’t … I import the audio track into the
    session side … then I clean up what I need to on the
    edit side, bring it back, copy, or bounce it by
    highlighting it and move my cursor to the next track and
    repeat to track 3 then I remove the original mixdown so
    I have it if I need it at some other time
    4. Now I take track 2 into the edit side and delete to
    bottom or right wave leaving just the left bring it back
    to the session side, highlight and mix it down to track
    1 as a mono wave file … I then repeat this for the
    copy in track 3 only you delete the left left track and
    mix it down to track 2 as a mono file …
    5. Now pan the left -35 and the right 35, mixdown and
    hardlimit to -1db, save and import it back into Pre Pro
    and replace to old audio
    with this file, it sounds involved like I said but really
    isn’t and you will be lovin how good it sounds …
    Audition has a multi-channel encoder in the program … On
    the session side go to VIEW > MULTI-CHANNEL ENCODER …
    Absolutely!!!!! Today there are a ton of powered monitors
    out there I use the Events and I love them, but they come
    in all kinds of price ranges to fit your pocketbook …
    https://www.americanmusical.com/item–i-EVE-TR8.html
    Hope this helps, Oh by the way if you don’t have a DUAL PROCESSOR in your computer don’t go with 2.0, Audition 2.0 kind of sucks also 1.5 is the bomb … E-mail me at loganonestudio@aol.com I have some other suggestions that may help ………… WILLIE
