Activity › Forums › Avid Media Composer › Audio workflow
  • Audio workflow
    Posted by Carlos E. martinez on August 10, 2006 at 1:06 pm
    I am willing to do my audio mix in external programs, like Nuendo, Audition or Protools.
    How do I export from Avid Xpress Pro or what do I export from it?
    Then how do I proceed to make a DVD using that mixed audio?
    Usually I export with QT Reference, which provides me with a mov file, then using Procoder to convert onto MPEG2. Then burn the DVD from it. I guess I can export my mixed audio as wav file, then using that audio on my burn.
    David Braswell replied 20 years, 1 month ago 2 Members · 3 Replies
  • David Braswell
    August 12, 2006 at 10:17 pm
    Carlos, individual workflow and personal preference will dictate the best way to handle Avid audio externally. I do corporate, broadcast, and web video work, and sweeten my audio in Audition. In preferences, if you tell the QT reference to “mixdown audio tracks”, you will get a separate aiff or wave (your choice) file when you export your ref mov. I then open the audio file in Audition, sweeten it, and import it into my project. This works great for me. I follow same flow when I burn DVDs.
  • Carlos E. martinez
    August 14, 2006 at 2:15 am
    Weel, one thing I would like to preserve are the original tracks, in order to do the mix in the sweetening program.
    Is there a way to do that?
  • David Braswell
    August 14, 2006 at 1:44 pm
    Exporting a reference mov with mixed down audio doesn’t erase or destroy your original tracks: it creates a new aiff or wav file of the audio. Once you import the sweetened audio back in, you can simply place it on another set of tracks until you’re satisfied with it. Even if you overwrote your original audio in the sequence, you could still get back to it by matchframing the video clip you’re working with.
    If you’re asking for a way to preserve the original mix of audio in layers so that you can sweeten the entire mix in your audio program, you can create an OMF file of your audio track. Upon import, your audio program should separate it into layers with each clip having the same name as in the Avid. Audition 1.5 doesn’t read OMF files, but I think 2.0 does. Recent versions of Cakewalk Sonar (I have 4.0) do read OMF files. I’ve tried this with a short film of mine and it was amazing to see all my VO, music, and SFX audio layers intact 🙂
