  • Posted by Burt Holland on December 21, 2005 at 3:17 pm
    I’m having a terrible time trying to correct poorly captured audio in FCP. The scene is two talking heads, and I’m having to tinker a lot to get their levels and especially their tone to match.
    My biggest problem however is that when I put on or pull of audio effects, FCP isn’t responding correctly. For instance, I had a gate on a clip, then removed it, but it stays on the clip. I remixed the audio down(command option R). Still there. I trash the audio render files, still there. I have to go back and get the original clip in order to eliminate the effect. There are a lot of cuts to correct stumbles, and now I can’t tell what sounds best because I don’t even know what the effect is that is applied to each clip.
    I can tell that FCP is referencing the effects because I am having to render audio with just 3 tracks, despite all tracks showing no filters. What is happening? Any suggested fixes? I know Soundtrack Pro would be a better option, but I don’t have a lot of time and I’m not really well versed in it yet. I have tried adjusting Audio Quality level with no differences.
    Dual 2.5 G5
    FCP 5.0.4
    OS 10.4.3
    Decklink Extreme
    Blackmagic Uncompressed 8-bit
    Promax SATA Max RAID
    Burt Holland replied 20 years, 9 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    December 21, 2005 at 6:06 pm
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Michaelle Stikich
    December 22, 2005 at 12:12 am
    Did this just start happening when you upgraded to FCP 5.04? Or was it happening before?
    Just wondering if this is only a problem in the newest FCP.
    thanks
    gir
  • Burt Holland
    December 22, 2005 at 12:50 am
    Just since the upgrade that I’ve noticed. I moved the audio render to a seperate RAID and trashed the preferences again(I had done it 2 days ago) and I seem to be having less issues. Don’t know which helped.
