Activity Forums Adobe Premiere Pro Audio will not play in Source monitor
  • Audio will not play in Source monitor
    Posted by Richard Hutt on June 21, 2011 at 2:51 pm
    Hey
    When i load clips into the source monitor, the audio will not play. If I drag the clip to the timeline, the audio plays. IS there a setting somewhere that has gotten un-checked. This problem does not do this on all clips.
    Thanks for any help
    Richard
    Richard Hutt replied 14 years, 9 months ago 2 Members · 2 Replies
  • Alex Udell
    June 21, 2011 at 4:08 pm
    Are you using any 3rd party hardware like Matrox in your setup?
    Alex
  • Richard Hutt
    December 7, 2011 at 11:33 am
    Alex Its been awhile since i posted this problem but I thank you for getting back to it. If your still out there, the answer to your question is, no I am not using Matrox or any third party HW that i am aware of.
    This problem seems to happen when I change to a different workspace within a project that was created on another editor.
    Let me explain. We have 3 editors tied to the same Server. 2 of the editors are running Premiere Pro 5.5 while mine runs PP 5.0 ( Don’t ask me why, I’ve asked for the upgrade) All 3 editors work on projects together through the server. If I open up a project created on one of their editing stations, and change the their Workspace to My Workspace Settings, then this problem with the audio occurs. So my thought are that somewhere in some settings window I can fix this. Unfortunately I haven’t been able to find this setting to change.
    Thanks for any help you can give me.
    richard
