Activity › Forums › Apple Final Cut Pro Legacy › audio weird
audio weird
Posted by Melissa on May 10, 2005 at 5:13 pmI digitized some clips with two mono tracks. When I created a different project, the same media imported with stereo audio. What can I do? Why would this happen? Can I unlink the audio with in the clip with out having to put it into a sequence?
Also the clips are playing back very choppy…
Thanks!!!John Fishbackreplied 21 years, 4 months ago 3 Members · 3 Replies
Thaxter Clavemarlton
May 10, 2005 at 9:24 pmThe audio is very easy to change during the edit.
If you captured two channels, you can choose to edit only one (either) channel or both.
You can “pan” any channel to center, left, right or anywhere in-between.You can separate or create any “stereo pair” by clicking on the track in question and hitting “option-L”.
I sometimes spend as much time setting and adjusting my audio tracks as I do on the video.
It depends on how the tracks were recorded and how I’m using them. -
John Fishback
May 11, 2005 at 6:06 pmI’m not sure how to do this in the Viewer (if it’s even possible there), but when the clip is in the sequence timeline, if you select it and then option-L it should should change from stereo to 2 mono tracks. There’s also the Stereo Pair selection in the Modify menu that will do the same thing.
I’m not sure why the audio would play choppy. Check to see of the sample rates of the sequence and files match. If you have a lot of audio tracks try mixing them down. Perhaps you’re stressing your processor.
John
Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
Cinema 23 Radeon 9800
FCP4.5 DVDSP 3.0.2
Huge U-320R 1TB Raid 3 firmware ENG12.BIN
ATTO UL4D driver 3.20
AJA IO driver 1.3.1 firmware v21-26
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors -
John Fishback
May 11, 2005 at 6:14 pmI’m not sure how to do this in the Viewer (if it’s even possible there), but when the clip is in the sequence timeline, if you select it and then option-L it should should change from stereo to 2 mono tracks. There’s also the Stereo Pair selection in the Modify menu that will do the same thing.
John
FCP4.5 DVDSP 3.0.2
