Activity Forums Apple Final Cut Pro Audio waveforms not showing up
  • Audio waveforms not showing up
    Posted by John Younger on February 5, 2016 at 12:15 am
    Little confusing so ill try and be as clear as possible.
    2 cams with audio and a boom audio source were synched in plural eyes 3.5 and a multi clip was sent to fop x directly from Pluraleyes.
    I thought it had made the jump ok, so i started editing away. Then i noticed the boom audio (wav.) was there and in the correct spot, but there are no waveforms and i can’t hear the audio as well.
    See image here:
    https://images.creativecow.net/51850/screen112.png
    I initially tried to sync via FCP X but didn’t work out. I did rename camera name of the audio, but unclear if that affects anything. The naming was prior to plural eyes workflow.
    I also tried relink directly to original audio which appeared to do nothing.
    Thoughts?
    John Younger replied 10 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
