audio waveforms do not correspond to actual sound
Hi all – I am experiencing issues of the audio waveforms not corresponding to their actual sounds in the timeline. Everything is fine in the viewer, but dragging a clip to the timeline will render unusable waveforms. I tried throwing away all waveform caches and audio render files, restarted repeatedly, repaired my hard disk, whatever I could think of. Working off a dedicated Glyph drive with plenty of room. Tried the project on someone else’s computer, and the problem still occurred, so shouldn’t be a problem with my version of FCP 7.0.2.
I am working on a project that combines 2 different components: A) individual chapters (separate sequences) made up of still images and sound captured on a mini disc or Zoom H4n external recorder, 44.1 kHz. and B) an introduction mixing these formats with additional Canon 5D HDSLR footage.
Things were going swimmingly in the audio/still category at first. I had set up the stills only sequences as 29.97 HD (1440×1080) (16:9) files, and everything worked fine.
Then I created an easy set-up of a PAL framerate to be able to sync my 5D footage to the external audio recordings of the Zoom H4n. This step was recommended by Apple — https://support.apple.com/kb/TS1256 — and this user forum: https://brucesharpe.blogspot.com/2010/02/dslr-sync-drift-in-final-cut-pro.html
Within those sequences, no problems at first, either, with the sequence settings at 30 fps.
Then, eventually, problems began to appear when audio from the stills chapters that I imported into the video sequence began showing signs of slipping away from its waveform representation. I initially fixed that by creating a new sequence at 29.97 fps for a part of the intro that doesn’t use any video, and figured I’d deal with it later. But then a new stills/audio only chapter I created started showing the same issues. It only contains external audio at this point, it’s set the same as all my other 29.97 stills sequences, which worked fine.
Researching this issue, I came across this recent thread and work-around: https://forums.creativecow.net/thread/8/1067267#1092226
I did follow instructions of creating a PAL Easy Set-up again, and restarted, and re-imported the audio into my bins. Creating a brand new 25fps sequence allowed me to work with the clip I was having the issues with before. But I am concerned about consistency, and having several half-finished sequences at 29.97 that I still need to work with. I will also have to work in the 30fps 5D video sequence, where importing stand-alone audio all of a sudden became an issue. looking to create some sort of set-up that can work for both scenarios, and could even split up the stills and video parts into two projects, if that seems helpful.Also wondering whether it might be an issue of 44.1 vs 48 KHz? I didn’t convert the files initially, and now have tons and tons of subclips I created to build my edits, and understand that I wouldn’t be able to reconnect the media to those if I now converted.
Very confusing. Any thoughts??? Very much appreciated……. thanks. Katja
FCP 7.0.2. — Snow Leopard 10.6.4 — Mac Pro 2×2.66. GHz Dual Core Intel Xeon, 4GB 667 MHz DDR2 FB-DIMM
Want better production audio?:
