Activity › Forums › Adobe Premiere Pro › Audio waveforms disappeared from clips in timeline
Shelia Chase replied 11 years, 3 months ago 10 Members · 13 Replies
Gavin Binder
December 5, 2012 at 11:34 amHi there,
I don’t know if this is the same problem as you are having – but I just had a similar thing and it turned out it was a clip conforming issue.
I updated to 6.0.2 and all my audio vanished, waveforms, clips, everything.. I noticed at the bottom that it was conforming all the clips again (I’m using MXF’s recorded on a Canon C300). Once they had comformed the relevant clips the audio reappeared. It was quite quick for me as I am running a powerful machine with 48gb of RAM, it may take longer for others – but I’d check that your clips are simply still not comforming before try anything more drastic. Especially if you’ve recently done an update or something which has changed the media.
Good luck,
Gavin.
Reinaldo Torres
May 26, 2015 at 1:54 pmSolution:
Close Premiere Pro and start up the project by holding the Shift Key. It seems it resets the preferences of Premiere Pro and resolves many other problems like not recognizing reconnected files and such. -
Shelia Chase
June 18, 2015 at 2:03 pmI tried about four different troubleshooting solutions and holding the shift key until all files conformed worked, thx!!!
