Activity › Forums › Adobe After Effects › Audio Waveform – that doesn’t move from right to left
Posted by Martin Gardiner on April 26, 2019 at 3:26 pmIs there a way to just have the audio waves get bigger and smaller, but without it moving from one side of the screen to the other?
Kalleheikki Kannisto replied 7 years, 4 months ago 5 Members · 6 Replies -
Gary Milligan
April 26, 2019 at 4:35 pm -
Gary Milligan
April 26, 2019 at 4:38 pmOops! Just realized I was talking about Premiere Pro… not After Effects.
Gary
Greg Gesch
April 26, 2019 at 11:20 pmHi Martin, it’s hard to understand what you mean, can you explain what you require in more detail?
Mark Whitney
April 27, 2019 at 2:18 pmI think what you might be after is expanding the height of an audio row.
On the timeline, if you position your cursor on the bottom edge, I think on the left side where the labels are, it should change so you can drag up & down to change the row height & allowing the waveform to be more visible.
Martin Gardiner
May 2, 2019 at 2:23 pmSorry, I meant the effect ‘audio waveform’ – not a timeline feature. I want to apply the effect to a solid and just have the waveforms get bigger and smaller, but not scroll from right to left.
Is there a way to do this?
May 2, 2019 at 3:20 pmI think you’re looking for something like audio spectrum rather than audio waveform. Audio waves move through time.
Senior Graphic Designer
