Activity › Forums › Apple Final Cut Pro Legacy › Audio Waveform Question
Posted by Jesse on August 29, 2005 at 5:54 pmWhy don’t the audio waveforms show (even though the option is checked under my prefs)? Any suggestions? Seems like it only works when it wants to.
Thanks in advance, Jess
Dekkoman replied 21 years ago 5 Members · 5 Replies -
David Bogie
August 29, 2005 at 6:13 pmthe audio track display has to be a certain height. I forget what it is but drag one of them (or use the size thingy) till it’s a bit larger and the waveform will pop into view.
bogiesan
Todd Beabout
August 29, 2005 at 8:14 pmIf you created the sequence before you set up your prefs to display waveforms, they won’t display without changing the timeline settings. (Click the small triangle near the bottom left of your timeline to change settings for that timeline.)
Any new sequence you start after changing your prefs should dislpay the waveforms though… If they don’t look at re-sizing your tracks as boogiesan described.
-Todd Beabout
Vazda Studios -
Wilhelm Beck
August 29, 2005 at 8:48 pmAnother option is to check your CURRENT sequence settings, cmd-zero.
Then you
David Bogie
August 29, 2005 at 8:58 pmSince FCPv1 I’ve wanted a control-click inside any single audio clip: Show Waveform.
It’s silly to change modes to a prefs or a settings panel just to get a few audio hits pinpointed.bogiesan
Dekkoman
August 29, 2005 at 10:36 pmYou can also hit ‘command-option W’ to toggle the displaying of all waveforms without having to go to the preferences window.
Tim
