Activity Forums Avid Media Composer Audio Waveform Hidden unless area marked in/out
  • Audio Waveform Hidden unless area marked in/out
    Posted by Alex Bond on September 12, 2007 at 7:08 am
    Sorry for the dumb questions – there will be a few!
    I’ve managed to alter the display of the timeline so you can no longer select and view the Audio waveform on audio tracks unless you mark and in/out. You are also unable to see the level nodes I’ve put in, all you get is the Audio chunk outlined with a small pink triangle pointing upwards in the middle of the clip.
    Any ideas what I’ve done and how I can revert it? I’ve tried reseting to default or creating a new user profile however neither of these worked.
    Alex
    Alex Bond replied 18 years, 11 months ago 2 Members · 2 Replies
  • Michael Phillips
    September 12, 2007 at 10:21 am
    Go to timeline settings and uncheck the waveforms between marks preference.
    Michael
    anything 24fps
  • Alex Bond
    September 12, 2007 at 1:07 pm
    cool, thanks 🙂
