Activity › Forums › Apple Final Cut Pro Legacy › Audio waveform
  • Ben Insler
    August 3, 2005 at 7:01 pm
    there are little divider lines between the audio track names (i.e. between the indicator A1 and A2 on the left of your timeline). put your mouse over the divider line that is beneath the track you want to enlarge and drag it down to enlarge the display.
    Ben Insler
    Editor
    Telemark Films
  • Matt Larson
    Are your tracks as large as they can be? (Control+T adjusts the size)
    Otherwise double click on your waveforms in the timeline to pop them into the viewer. Then you can grab the clip’s name tab (top left corner) and drag it out of the viewer into it’s own window and adjust the size from there.
  • Bret Williams
    August 3, 2005 at 7:59 pm
    shift+t
  • Les Kaye
    August 4, 2005 at 6:09 am
    [videobiker] “Anyway to enlarge the waveform?”
    In a single word (that the others won’t use): NO. The other solutions resize the timeline tracks as well.
