Activity Forums Apple Final Cut Pro Legacy Audio wave not showing up
  • Audio wave not showing up
    Posted by Neal Fox on May 3, 2010 at 2:41 am
    I was running FCP on my old G5 and just reinstalled it on my new Mac Pro. It works fine except for one problem with audio files.
    When I double click an audio clip, the clip loads into the viewer but only part or none of the wave form shows. And when I try to work with key frames, I get trailing volume lines which make it almost impossible to see the actual volume line and keyframe.
    It also sometimes shows up as a negative. Black instead of white, etc.
    Any ideas?
    Thanks.
    Josh Bolton replied 14 years, 5 months ago 4 Members · 5 Replies
  • Anna Brownfield
    May 3, 2010 at 4:17 am
    mmm not sure but have you tried just showing waveforms in the timeline and keyframing them there instead? Option Command W will show your waveforms and option W will show your clip overlays…..might be easier to work that way instead!
  • Neal Fox
    May 3, 2010 at 11:50 am
    I’ll give it a shot. Always felt it easier to do it in the viewer. But I’d like to get to the bottom of this anyway.
    Thanks for the tip. I’ll try it tomorrow when I’m back at the studio.
  • Doug Beal
    May 3, 2010 at 7:58 pm
    Trash your waveform cache
    It’ll have to redraw and might take a bit, not an hour of anything like that
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Neal Fox
    May 4, 2010 at 11:59 am
    I’ll give it a shot. Where do I find the waveform cache?
  • Josh Bolton
    April 20, 2012 at 7:00 pm
    Thanks! Deleting the files in the waveform cache cleared up the problem for me.
