Activity › Forums › Avid Media Composer › Audio volume issues in Avid
Posted by Hunter on February 6, 2006 at 6:25 pmsadfasf
Smiling Editor replied 20 years, 7 months ago 4 Members · 9 Replies -
Hunter
February 6, 2006 at 6:28 pmSorry typing snafu. My audio problem is I recorded some Voice Over in Pro tools 6 LE and the volume and everything is great. I import into Avid Xpress Pro HD 5.1.6 and it is incredibly low. All other audio plays fine. Thanks in advance for your help.
Jon Zanone
February 7, 2006 at 12:34 pmDumb question – does all your audion sound low in the Avid, or is it just one clip?
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better” -
Geraint Pari huws
February 7, 2006 at 1:00 pmcheck in protools first, are you referenced to the same levels in both applications? As a long term check blow some zero level tone from protools to avid and check they correspond. Boring but at least you’ll be making a real comparison and can narrow down the problem. In the meantime just turn it up, if it was recorded real clean it should be ok.
Hunter
February 7, 2006 at 1:41 pmThanks for responding. Audio captured from my DV camera is fine. Imported music from audio CD’s is fine. It just any clip of audio recorded in Pro tools that I import into Avid its so low that even if I max. gain it at +12 its still low. When I record in Pro tools the level is fine, I turned it up in Pro tools to the point that the audio was almost peaking in the Red. When I do import into Avid I get a message about converting and the message has an 2 options one for coverting to 29.97 fps and another for non drop frames and have tried importing with both options selected. THanks for your help.
Geraint Pari huws
February 7, 2006 at 2:20 pmframe rate options shpold make no differance.
in what format are you exporting from protools? Are you exporting the clip directly or from the protolls timeline?
Hunter
February 7, 2006 at 10:31 pmI’m exporting as a wav. Actually I’m not exporting from Protools I’m just importing into Avid from the Protools audio files folder. I did notice that the Protools files are 24 bit and I wonder if Avid is changing it 16 bit upon import and this might cause the volume problem? thanks again
Geraint Pari huws
February 8, 2006 at 9:21 amok
check protools is working at the same operating level as your avid,
-18db/-20db whatever…
create a protools comp with zero level tone at the top on both legs
followed by your voice over adjusted to peak around -8db.export the comp as a wav and import to avid and compare meter readings, forget listening levels or perceived volumes to see where the problem lies…
Hunter
February 11, 2006 at 8:06 pmI think it has something to do with Avid levels upon pulling up some older clips I have the same problem where I can barely hear the audio, then yet another will be fine. Any way to adjust the audio with out just boosting the timeline volume or adding gain?
thanks -
Smiling Editor
February 14, 2006 at 2:40 pmI just started using the Avid a month ago but, in answer to your question, you can raise the overall output of your program to +6 in the audio settings>audio project>output menu.
My audio issue is with the MCA on my G5. All my digital audio files, aifs, that I used with my Media100 in the past are coming in extremely hot in the Avid. Also, any new files that I import. I get original music or narration, from an audio studio, as an mp3, I export it as an aif in Quick Time Pro to the specs I’m using in Avid (stereo or mono at 48k). After importing into the Avid, I need to lower these clips -15db using the Mix Tool before I edit them into the timeline. You can see on the Energy Plot that they are still very pumped (see mostly white and little detail) – they sound okay but, this doesn’t seem right. The other elements in the program are talking heads and ambience that I bring in from BetaSP. These levels all look normal and when I do a digital cut to tape – the levels are perfect. I’m using the default setting of -20db allowing peaks to hit -8. Is this a bug?
Nancy
