Activity Forums Adobe After Effects Expressions Audio Volume Down at the end
  • Audio Volume Down at the end
    Posted by Sergio Cabrera on May 27, 2019 at 9:28 pm
    Hello. I have a composition with an audio file inside, I need the audio to automatically volume down at the last 1 or 2 seconds at the end, even if I change the composition end time.
    I’m guessing the expression would be at the waveform, related to the comp end time – 2 seconds, then begin a gradual volume down in the waveform, but I don’t really know how to do this.
    Any help?
    Sergio Cabrera replied 7 years, 3 months ago 3 Members · 5 Replies
  • Dan Ebberts
    May 27, 2019 at 10:58 pm
    Something like this for Audio Levels:
    fadeDur = 2;
    fadeEnd = Math.min(outPoint,thisComp.duration);
    easeOut(time,fadeEnd-fadeDur,fadeEnd,value,[-192,-192])
    Dan
  • Sergio Cabrera
    May 28, 2019 at 2:43 am
    Thank you Dan, you are amazing.
    What “easeOut” alternatives are? It cuts the audio too abruptly even at 3 or 4 seconds, I need to make it smoother, like linear out?
  • Sergio Cabrera
    May 28, 2019 at 2:54 am
    I mean, easeOut is suposed to smooth at the end but it’s too abrupt anyway, any way to make the leveling smoother?
  • Tomas Bumbulevičius
    May 28, 2019 at 5:00 am
    Instead of [-192,-192] try something upper value like [-48,-48]. It should be still enough to fade out the sounds, and it won’t be that ‘fast’ drop.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Sergio Cabrera
    May 28, 2019 at 5:23 am
    Yes, -45,-45 works pretty nice. Thank you both!
