Activity Forums Apple Final Cut Pro Legacy Audio Volume after burning DVD
  • Audio Volume after burning DVD
    Posted by Gabriel Borba on April 7, 2011 at 1:26 am
    I’m not sure this question belongs in “Final Cut Pro” forums or some other place, but anyway:
    It’s an AUDIO thing, since the VIDEO part all worked out.
    > I used FCP7 to select 6 small clips from my original footage and I used Apply Normalization Gain on each of them so they would all be set to -12dB.
    > Then, I exported each one of them, one by one, as 6 separate .mov files, using Apple ProRes 422 (HQ) NTSC as codec.
    > I burned them all on a DVD as video using Toast Titanium 8, and when I watched it on TV one of the clips seemed to be louder than the other 5, even though on final cut they all reach max -12dB on the VU meters.
    > So I went back to FCP7, and used Apply Normalization Gain one more time on the “louder” clip and set it to -16dB. Exported, listen comparing to the old one, and burned another DVD using the new file and the other 5 that were ok.
    – It sounded the same as the first DVD.
    > So i wen’t back to FCP7 and this time I set all the other 5 clips to
    -10dB. Re-exported all, compared to the 5 old ones, burned a 3rd DVD (this time using the -16dB version of the first file, and the -10dB version of the other 5, leaving a wider dB gap between them).
    > Sounded just like the two first DVDs.
    > I ended up using it like that cause I had no more time for tests before playing the DVD on a Workshop.
    What is wrong?
    Am I missing something on FCP7?
    Is Toast Titanium 8 equalizing the audio tracks regardless off the volume I originally set for the clips on FCP7?
    Is it possible that my TV is equalizing the audio tracks when I play the DVD?
    Is there some other explanation?
    I searched for this thread but no success.
    Too many variables, that’s why I’m not even sure this is a FCP question, but if someone could help me I would appreciate a lot.
    Gabriel.
    Gabriel Borba replied 15 years, 4 months ago 2 Members · 2 Replies
  • Cody Walters
    April 7, 2011 at 2:09 pm
    From you explanation it sounds like Toast is normalizing your audio. I personally haven’t used Toast for burning DVDs. I just use DVD Studio Pro. I would check your settings in Toast…maybe there is a preference in there that is normalizing all audio to a certain level.
    Sorry if this isn’t help. Just my thoughts.
    Cody Walters
    Mac Pro 2.26GHz 8 Core
    16 GB 1066 MHz DDR3
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
    http://www.codywaltersvideo.com
  • Gabriel Borba
    April 7, 2011 at 2:14 pm
    I looked for it on Toast.
    There’s a “Enable Dithering” option and I can choose between TAO or DAO methods of burning. But I doubt they have anything to do with that.
    Well, I guess I could try it on DVDSP and see if it works better than Toast.
    Thanks anyway.
