Activity Forums Adobe After Effects Audio Visualization
  • Audio Visualization
    Posted by Mata Hari on December 2, 2012 at 10:21 pm
    Hi Cows,
    Been a while since I had last posted, but ran into a very interesting challenge that I need some help with.
    Here’s the source of inspiration:
    https://vimeo.com/6045312
    I’m sure there will be lots of challenges along the way, but the first one is kind of purely organizational. I figured that the artist have used more than one emitter, but for some reason even if I create two or more light sources named emitter of course they respond the exact same way to the audio. And why wouldn’t they, they assigned to the exact same particle system so it’s obvious that the control will be the same (Oh, man, it’s hard to even explain what the real question is:D)
    So what I would like to achieve is that I’d have separate controls over the separate emitters. Let’s say I have a piece of classical music (Handel: Water Music) which has different instruments. I’d like to be able to assign different emitters to different instruments (different frequencies) so I’d have more control over the particles over time.
    I hope it makes sense:)
    I have created something basic, but I’d like to experiment a bit more on this, here’s my experiment:
    https://youtu.be/umJ9rQAscdc
    The rendering time was 11 hours on i5, 16g ram, Nvidia GTS450, Win7 64, AE CS5, but my particle numbers were quite high (500.000/sec).
    So if anyone has an idea how do I go about this, I’d appreciate it.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Vishesh Arora replied 13 years, 9 months ago 3 Members · 3 Replies
