Activity › Forums › Adobe Premiere Pro › audio upmixing is not allowed
  • audio upmixing is not allowed
    Posted by Jim Michaels on June 10, 2008 at 6:51 am
    Adobe Premiere 1.5. Trying to export MPEG video (Preferably mono audio, not stereo default!).
    Tried my best to parse the adobe help, and the tech document on this subject: https://kb.adobe.com/selfservice/viewContent.do?externalId=332333&sliceId=2
    Document is a little vague in some spots. Like solution 1 & 3 gives no steps, and I have no clue how to perform it. (help).
    I have 2 partially overlapping mono-audio video clips.
    There are 3 audio channels: 4, 5, Master.
    I performed step 2: creating a new sequence, going to project window, dragging old sequence to new sequence, Making sure new sequence has only a mono channel.
    Also, I would like to know:
    Do people still have this problem in CS3?
    Does CS3 work on 2.8GHz HT boxes? I saw the System Requirements for 1.5 and CS3 and both are out of my system’s range, yet 1.5 will run on my 2.8GHz P4 HT (think’s it’s a dual core) except when doing 640×480 video.
    Ann Bens replied 18 years, 3 months ago 2 Members · 1 Reply
  • Ann Bens
    June 10, 2008 at 9:27 pm
    If you want your output to be stereo you need to set the sequence to stereo even if there is just mono sound added.
