Activity Forums Avid Media Composer Audio Underrun on DV Device
  • Audio Underrun on DV Device
    Posted by Mike Burchett on December 18, 2006 at 7:11 pm
    Hi guys,
    I’m having difficulties exporting a timeline to tape with XPress Pro. It works fine for roughly fifteen to twenty minutes but then aborts and gives me the error: “Excpetion: Audio Underrun on DV Device.” It happens at random points and never repeats the error at the same point.
    I wary of trying insert where it stopped recording because I’m prepping this for an online master.
    I am running Xpress Pro 5.6.2 on a PowerMac G5 with Dual 2Ghz, 2.5 GB Ram. OSX v10.4.7 with a LaCie 1Tb Big Disk connected via Firewire 800. I am exporting to a Panasonic AG-DVX100A via FW 400.
    Any ideas?
    Psimpso replied 19 years, 8 months ago 4 Members · 4 Replies
  • Ralph Bertini
    December 20, 2006 at 1:46 pm
    Are you using mojo?
  • Michael Hancock
    December 20, 2006 at 11:19 pm
    How complicated is your edit, and what resolution are you working at?
    You might want to try duplicating your sequence and doing a video mixdown of your duplicate. Then try to lay the video mixdown to tape. Also, if you are running with Mojo it could be causing problems. Try disconnecting it and then output to tape.
    Mike.
  • Mike Burchett
    December 21, 2006 at 10:22 pm
    It’s a pretty simple edit. No titles or effects. And we’re not using a Mojo. I’m still looking for a work around.
  • Psimpso
    January 16, 2007 at 6:29 am
    We too have run in to the same thing on at least one G5 where I work.
