Activity Forums Apple Final Cut Pro Legacy Audio Transition
  • Audio Transition
    Posted by Rob Grauert on March 19, 2008 at 7:39 am
    Hey,
    I normally use the ‘cross fade(+0dB)’ transition when I cross fade audio rather than the ‘cross fade(+3dB),’ which is set as the default transition in the menu when I right-click at the cut. Is there a way to include the ‘cross fade(+0dB)’ in that right-click menu and adjust the length so I don’t have to keep dragging and dropping from the audio transition folder from the effects tab? It would make things go so much faster.
    Rob G.
    Jeff Pierce replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jeff Pierce
    March 19, 2008 at 3:36 pm
    Go the the Effects tab.
    Enter the desired transition duration in the “Length” column.
    Right click on the transition.
    Select “Set Default Transition”
    Now that transition — with that duration — is your default audio transition, which is selected by right clicking within the timeline.
    FYI: same procedure works for setting your default video transition.
    Hope that helps.
    Jeff Pierce
